This is my first post and I apologize because I know if I spend hours and hours searching through prior posts I will be able to discern exactly what I have. However, I'm anxious to get some parts ordered and suspect that many of you will be able to identify exactly what I've got.
Specifically I was told by the seller that the chassis (including motor, drive train, steering gear, and some sheet metal) is a 1929 pickup. However, the engine serial number suggests that its a 1930 (October) production run. I realize that over 92 or 93 years parts have probably been swapped out so it would be great if some of you could help me understand exactly what I've got.
1. The firewall style and engine serial number seem to suggest that it's a 1930. The firewall is beaded (which I understand started in 1930) and the serial # is: A4012xxx which from research suggests October 1930. Am I correct that the firewall and engine are 1930?
2. The radiator appears to be from a 1929 because the bottom outlet is angled horizontally and outward at a 30-degree +/- angle. I just picked up the chassis last week and the radiator is at the radiator shop (old school guys, he recognized it and understands how it functions). But, in the event that I need to replace the radiator, I'd like to make sure its correct for the year. Naturally, I'm hoping to verify that the radiator cowl is also 1929.
3. Is there a definitive way to know that this is a pickup chassis? Or more importantly, is the pickup chassis different from others?
4. The front rims look like 21" (i.e. 1928/1929) and the rears smaller. The chassis isn't here at the house so I can't give specific measurements, but is there any information about the rims that is obvious to anyone.
5. Related to the rim question above, do all Model As have the same bolt pattern and are the rims interchangeable?
Thanks in advance, and again I apologize for the basic questions, but want to put this back together as accurately as possible, and at the same time, avoid ordering and returning parts that were incorrectly ordered.
PS: it was advertised as "Ran when parked" - haha!
