markwill
I have a relatively rust free tudor that I'm restoring, however, the subframe underneath both "A" Pillars was rusted, so I cut out the rusted area and welded in a section of good subframe that came from another Model A tudor...all went well and the patches are flat and true across the length of the subframe. At the top of the "A" pillars, there was metal fatigue and the right angles that come off the top of the pillar that are normally riveted to the metal that forms the top of the door jambs were cracked off and missing. I rebuilt this area (see pic) with new metal and temporarily install a machine screw where a rivet is supposed to go to see how everything lines up.
The problem is the drivers side door is about a half inch too low (based on the belt line) at the latch. I can remove the temp machine screw I installed and spread the top of the door jamb and it raise the door so the belt line aligns, but this throws off where everything was originally riveted. I did this exact same repair to the passengers side and everything is in perfect alignment, therefore I'm clueless on how to go about solving this.
1 Should I go ahead and rivet the top of the "A" pillar so the original holes align and try to correct the door alignment with shims in the body mounts?
2. Should I expand the top of the jamb until the door aligns correctly and re-install the the rivets at the top of the "A" pillar in the new positions.
I should mention that the door was misaligned when I started, but I attributed that to the fact that there was nothing connecting the top of the "A" pillar to the cross brace at the top of the door jamb holding everything square.
I hope all this makes sense.
Thoughts??? Help!
Thanks, Mark
Thoughts??? Help!
Thanks, Mark
