1928 Tudor Brakes?
Sly
Hi there,
does anybody know the exact measurement (length) of the:
Brake adjusting shafts, located in the drums?
Best regard Stefan
I don't know what the actual length is,but the important thing is that the length is the same on each pair used in each brake.If you clamp a bolt,or a rod the size of the adjuster pin holes in a vise you can stack a bunch of them up to compare.I've heard of some being different lengths from being ground.I only found a couple that way.
