C craigreavley Member Apr 4, 2013 #1 I cannot get the radiator cap off the truck to check the antifreeze. It is unthreaded all the way, and appears loose, but it will not come off. What am I doing wrong here?
Chris Haynes Well-known member Apr 4, 2013 #2 If it was unthreaded all the way it would be off the radiator.
B Big John Senior Member Apr 4, 2013 #3 is it a stock cap or a locking type of some kind.???...some old accessory caps had a lock of some variety.....if stock, yes it should fall off.....
Joe K Well-known member Apr 4, 2013 #4 Or maybe you've broken the solder joint between the threaded neck and the upper water box? You may be just turning and turning and turning? Try looking below the cap and above the radiator shroud - you may catch a glimpse of the radiator fill neck. Joe K
