1928 Open Cab Pick-up Wire Routing
flybob08
Can someone explain the proper way to route the wiring for the rear stop/tail lamp from the rear axle aft to the light out on the bracket. e.g. how do you handle the wiring after the lower frame rail ends by the axle.
Thanks
Bob
Don’t know if this is per any judging guidelines, but on my ‘30 OCPU the harness leaves the lower frame, just goes over the axle to a tie-down block behind the axle, then into a flex conduit, to the light.
Tried to attach a couple pics, but the forum is not cooperating.
Make your picture files smaller. Jpg works best.
