Omar Morales
Hello All,
After much troubleshooting, parts replacements and speedo testing, I believe I may have found the culprit.
I believe the torque tube speedo gear assembly is missing the snap ring. The gear itself slides back and forth freely.
Are you able to tell from these pictures if that is the case? If so, are you able to tell from the pictures where it goes?
Thank you!!
Thank you!!
