1928 Ford Coupe running project
fordtrk56
Temecula
Ca
Price
$8950
1928 Coupe in running condition with non op title in my name.Original FORD script wrench set.Good floor wood set with some hand crafted rear cab wood plus good top wood bows.Workiing original gas tank with new sender.New 12V battery.Balanced 4 banger that has new rings,aluminum timing gear,new spark plugs,fresh magnafluxed head,fresh oil,new copper head gasket,valve cover gasket,water pump gasket,timing cover gasket,conventional points and cap with rubber wires,12V conversion with alternator.Existing wiring works but does need updated.Nickle plated exhaust/intake manifolds.It has a 1929 radiator with new core,,flying Quail cap,new shell and stone guard.Lights and turn signals work plus Pontiac tail lights.Good brake shoes.Front fenders,running boards,used hood,,rear bumper assembly,60's style seat covering and door panels.Windshield is glass.All others are plexiglass.1940 steering wheel and horn button so no head light adjuster at top of column.Good muffler and pipes.Decklid with new skin.More pix available if needed and local delivery available too.Have video to share of the engine running..760-717-1334
