1928 Fenders
rafter
Can I bolt 1930/31 fenders onto my 28' Sedan? will they line up blot hole wise or will I have to modify them?
Thanks, Rafter
Yes, you can put them on using the aprons and running boards that go with the fenders. You will also need the 30-31 front fender braces and headlight bar. You will also need to use the 28-29 hood shelves. Don't know if the holes in the frame are the same or not.
