TK in LA
- City
- La Verne
- State
- Ca.
- Price
- 2000
For your consideration is this completely rebuilt, Diamond block Model A motor. It was setup to be used in a '28 or 29 vehicle. (no vacuum port in the intake and short outlet) but was barely run and was removed from the vehicle and stored for many years. It will fit all years if you change intake and water outlet. I've completely disassembled and verified everything is correct. Counter weighted and balanced crankshaft. Fresh bored block with new pistons and rings. New Babbitt in rods and block. Looks to be a touring or RV type cam. New timing gear setup, leakless water pump and new fan belt, rebuilt oil pump. Fresh valve job with adjustable lifters. Flywheel was resurfaced with new starter ring. Rebuilt distributor and new plugs. This includes the starter and working generator. Carburetor was rebuilt but was also sitting for quite awhile. I have only run the motor on my test stand and there are no guarantees as to future reliability or performance. What you see is what you get. No overheating or leak issues. Includes everything in pictures except any parts for my test setup. $2000.00 First come, first serve. Come hear it run and check it out on my test bed for yourself. Would cost over $3 grand to do the came thing to your motor. Shipping not available but can deliver locally for a small fee. It is still available and will be marked as pending or deleted upon sale. Motor is located in La Verne, Ca.. ****More pictures available****
