visionary
Hey guys, i've got my motor back from snyders and i've had it running for just a couple of minutes as the radiator isn't installed just yet, and this is what i need a little help with. when i removed the radiator eatch side had one spring on the underside of the frame and none on the top side of the frame, when i purchased a new mount kit it came with two studs 4 springs and 2 inner and 2 outer cup washers.
Now here's where my dillema comes into play the mounting studs measure 21 7/8 from stud to stud as does the center to center distance of the radiator apron. but the mounting holes in the radiator itself only come in at 21 1/4 so needless to say the mounting studs are favoring the outer edges of the radiator mount holes and not centered. so there's no way i could use the inner cup washer or top spring, or are these even used on a 26?
Looking foreward to your help.
Thanks
Scott
Thanks
Scott
