I'm not sure if the '26 had a magneto powered horn. If it is a mag. horn it won't work on 6 vts. DC. ( the mag. puts out AC current). Also check it it has more than 1 terminal or electrical connection. Some of them (depending on manif.) did not ground thru the horn body and need to be grounded thru this second terminal. Hope this helps. Power path for a mag. horn is: from the mag. terminal at the junction on the firewall, through the horn button then to the horn. Ground wire, if necessary, goes from the horn to the eng. block.
