1926-27 Touring car
toms32
I just recently purchasd a 1926-27 touring body. Some of the top irons are broken and one windshield post is cut off. Does any one have any close up photo's and dimensions that they could share so I can obtain some replacement parts. Thanks for any assistance on this. If anyone has any extra parts this could also help. Tom
Tom, I believe the 26/27 windshield post are the only ones with a three bolt mounting to the body. Also the part against the body is pointed where the earlier post were flat with two screw mounting. I do not know where you live, but the big Hershey swap meet is coming up next month. They are very large and most Model T parts show up there. Probably more parts than you can haul.
There are at least two different versions of the '26-27 windshield posts. I don't know if they interchange. There are at least two different versions of cowls (very slightly different on the outside at the post mount area), and the difference in the posts may correspond to the different cowls. I believe that you will need to post pics before you can be advised which you need.
