hello we have a 1925 model t we are getting smoke from where the throttle rod pass through the engine to the carburetor it is real bad we thought it may be the head gasket but no water in oil any ideas
thank you
kevin
thank you for the replys this weekend i will be pulling the valve cover to look at the valve guides and clean out the drain holes how many are there and where do i find them the engine has only been run with non detueangt oil so may have a build up if we where to change to rotilla would there be any harm to the Babbitt
thank you kevin
