- City
- San Diego
- State
- Ca.
- Price
- 4800
1923 T bucket with new Speedway boxed and painted chassis, fiberglass body and bed. Ford 289-needs rebuilt,AOD trans,electronic distributor,new plugs and wires,2bbl carb with air scoop, 8.8 rear end with 3:08 gears and disc brakes, headers, 11" front disc brakes.New steel and braided brake lines, master cylinder, adjustable proportioning valve and pedal assembly all installed and working. Ladder bars front/rear, rear coil over shocks, Vega steering box with Borgeson joint attached to a Speedway aluminum column with Grant wheel and horn kit, new wiring kit with dimmer switch, head light switch, ignition switch, Autometer Speedo, oil, temp gauges, new aluminum radiator, Model T grille shell, 2 piece Model T windshield frame-no glass, stock Model T round gas tank, partially upholstered, wood floor inserts already made and installed, New 15" Centerline aluminum rear wheels with new tires and 5x4 ½ bolt pattern front/rear...Registered in owner's name as a 1923 Model T..
