1921 etal wheel press
Will the funproject wheel press work for the 30 inch wood spoke wheels. When I look at the design it appears to be for a 21 inch wheel. Am I missing something? If I am then please let me know what it is I'm not seeing. If it is tailored toward the 21" only I'll get busy and change the design to accomodate the 30"
The Funproject plans are for the 21 inch wheel. It is a good design as I built one and used it very successfully. I would recommend just expanding the hex ring to accommodate the 31. Should be a piece of cake. Good luck.
Thanks racemo. The wheel press is built and appears it will work quite well. I can't wait to try it out. It makes sense and if it works as good as it appears it will, I may become a respoking fool.
