Ed in Maine
Today the parts arrived to refurbish the valves. I got some fine lapping compound and the lapping tool. I had no trouble removing the valves one at a time to be sure I don't mix them up. Using the lapping compound I find that some valves do have a bright ring around the valve seat and other valves have just a smooth grey, colored seat. I would have thought that after using the lapping compound, the valve seats would have gotten bright and shinny. I know I don't want to over due the lapping and change the valve gap but how do you know when you have done enough? The valves do look good, there are no burned out spots. But in most cases, the seats are just smooth, grey and dirty looking.
I haven't checked the valve gaps yet but did slip a piece of paper between the push rod and the valve stem on the lapped valves to be sure that there was some gap. There was a gap in all cases. As a side comment, that lapping tool is not easy to use. The rubber cup is always slipping off the valve. There has to be a better way to turn the valves! Any comments will be appreciated. Ed
