Ed in Maine
I know this topic is as old as the car is. Today I took four neighborhood children and one adult for a 8 mi. ride. Temperature outside was about 80 F. The car did run good with no missing. I wish it had a bit more power but what Model T owner didn't wish for the same thing! By the time I got the car back in the garage it was gurgling and pushing steam out the overflow tube. It gurgled about three minutes after the engine was turned off. The following applies to this car:
1. Tire pressure is 65 psi front tires and 70 psi in the rear tires.
2. New radiator
3. There is no water pump.
4. New Anderson timer.
5. Recent rebuild on an NH Carb that does give a quick start and runs nicely.
Is there anything I am missing that I could do to make the car cooler? Is it possible that the ethanol in the gas could be decreasing the available power and making the car run hotter? Has anyone experimented with an electric water pump? I do have a 12 V battery under the rear seat to run the coils on a start. I use the mag after the car is running. The car cannot be left running at an idle if I want to stop and talk with someone. It will be boiling within minutes.
Thank you for any comments. Ed
2. New radiator
