Thomas T
I have completed all of the engineering and drawings to build a replica of a Field Truck Body, Truck Cab, that were built for Ford Motor Co back in the mid-to late 1900's. I have placed an order to have all of the water-jet cutout work on the aluminum sheet material. The entire exterior body will be made using aluminum instead of the original sheet steel. The "skeleton" or interior frame work will be fabricated using various sizes of steel square and rectangle tubing and the skin will be fastened to the frame work with Cherry-Max rivets. The design criteria is to make the Truck looks as close as possible to one of Fields’s Light Express bodies that were placed on a stock Model T chassis. I am posting all of the information and photos at www.tomsoldbarn.com and would appreciate any positive comments or ideas with this project.
