Is there enough clearance to change the spindle bolts and bushings with the front axle mounted in the car with the tools that are offered by Langs? Has anyone used these tools and found them to be good quality? Ed
I'll add, the bushings are in the spindles not the axle so you have to remove the spindles to replace the bushings, face and ream. Which tools are you asking about?
