For Sale 1912 Engine/Trans
Mikebird
Goshen
IN
Price
1,500
1912 Model T Engine
Whole engine/trans. Casting date 8/7/12. The serial number is MICH3584. I'm guessing this was an engine that was used in a fleet for a vehicle in MICHIGAN or done for VIN purposes... IDK. The pan is correct for a late 12 engine. It has T cup with 3 rivet ears and front nose casting piece that goes all the way around hole. Earlier 12's had 7 rivet ears. The pan has the one piece ring which is correct for 1912. I opened up the oil pan inspection cover and it's really clean inside. Transcover is earlier style without reinforcements.
No head, valve covers, Trans inspection plate cover, timer, and missing two pedals. What you see is what you get.
$1500 Local pick up in Goshen Indiana or I can arrange shipping through Fastenall Blue Freight to select areas.
