180A front seat folding forward hinge
Yellowfordcoupe
Have a question about the rod that be the hinge for the fold forward front seats on a 180A. Do anybody have a picture of how they should look like? I think the ones on our 180A aren't the correct look.
Thanks, Alex
:rolleyes: OK, a week late on this question for pictures. I sent out my last set of New hinges to Allen Lapore[A+L parts] for his fathers 180A .His was in so so shape. The flat plate is 13- 1/2" long. by 1 -1/4" wide. the round tube welded to it is 16" long and 1/2" diam. It takes a steel rod 17- 3/4" long with a carriage bolt head on one side and threaded at the other 1- 1/4' long and goes thru the round tube with the same inside closed car window arm nut on the other side. In the flat steel plate there's 3 studs //from both ends 3/4" in and to center stud dead center 6-3/4" from end of plate- if this sound right then you have the correct ones. If you need the steel rods with the carriage bolt head on one side then order a set of repro radiator to firewall support rods and cut them down to 17-3/4" and rethread the one end.:D
