Herb Kephart
Have a question for you guys running Ford 16" wires.
Where do you get tubes with enough valve offset (from centerline) for the Ford rim valve hole. Started out with 16" tubes from Macs. Valves sheared off on initial instillation. When I call Macs about this they said that I was using the wrong rims, wouldn't take back the 3 still in plastic sealed bags, nor would they do anything about the ones that failed. Don't know why Ford 16" wires are "the wrong rims", unless they think they are selling Studebaker parts. End of me wasting my money at Mac's. Went to Coker site, and bought 5 tubes (for radial tires--which is what I was mounting) with "offset valve location''. Well, they are offset, but no where near enough. Got all 5 tires mounted, but on initial 5 mile run, valve ripped off, dumped all the air. Was in heavy traffic, and before I could get to a spot where I could pull off the road, brand new tire was trash. Ran the same (type) rims on my every day driver '31 pickup in the late 50's and early 60's, with never a thought about tubes--and if we couldn't find patchable old ones we ordered new from Sears. Top quality, I'm sure.
If I can't get the correct tubes, my only other option is to run the tires tubeless, but not sure if the bead seats are good enough to seal. Rims have been powder coated, which might smooth out small pits, but 80 year old rims are bound to be a long way from perfect in the bead area.
Tubes with enough valve offset have to be available---but where?
Herb Kephart
Herb Kephart
