I've been wondering around the garage, stirring up dust and pissing off spiders, looking for an axle. Does anyone know the thread pitch on the 15/16 rear axle nut?
The original rear axel nut is 5/8-18 , however, it is a special hardened nut. If you use a regular 5/8-18 nut and try to torque to 80-90 lbs. you could ruin the threads on the axel.
I do not know if the venders sell a hardened axel nut ? I have always used or located original nuts so I do not have to worry about screwing up an axel.
It is a good question, wonder if someone else might know the answer ?
