will.rynerson
Hi all,
I’m converting to a 12volt system from Vintage Auto Garage. I’m try to find out where some of you picked up Power of an electronic fuel pump and the voltage relay 12v to 6v. The directions say, “ connect to switched 12-volt power, such as ignition switch ACC or Ignition Terminal.
I was thinking of taking it from the ignition switch on the way to the coil.
