Will a volt meter designed to operate on 12V, if you use a voltage reducer to 6V work properly? I can purchase a S W 12 V battery voltmeter but I want to put it in my 34 roadster still on 6 volts.
Thanks;
B-O-B
Analog voltmeters aren't 12 volt or 6 volt. They will work on any voltage up to full scale. Now if full scale is 50 volts, you won't be able to tell 5 volts from 7 volts. If full scale is 15 volts, it may be possible. You really want full scale to exceed the maximum charge of your generator and to survive the maximum discharge of your battery through the voltmeter.
There was a thread on here a month or two ago, and IIRC, someone found a source for a decent voltmeter to be used for a 6 volt system. A "Search" should find the thread.
B-O-B
Since the 12 volt SW wings voltmeter scale reads from 10 to 16 volts. There is a way to still use the 12 volt SW gauge. By adding a DC to DC Boost Buck Converter Step Down Up Regulated Power Module you could feed this regulator with the cars 6 volt output and then adjust the regulated power module so the output feed will be 12 volts. Now when the car is running the 6 volts will show 12 volt on the gauge When you see the reading is 12 volt you know the car is charging. These regulated power supply's are easy to find on Ebay and most of them are less than $20.00 with free shipping.
Ronnieroadster
Please educate me on how that will work ??
A step up or step down regulator have a fixed output voltage...not like it is proportional to the input...
It works like I wrote feed in 6 volts it ill output where you set it you want the 12 volt out put thats what you get. There ADJUSTABLE for desired setting pretty easy to understand.
Ok so you will have it show 12v all the time...that´s as exciting as painting a needle on it with a crayon
Thought you had found some way of actually making them show what was going on with the 6v charging system...
A simple squarewave from a 555 timer and a voltage doubler would give you a 12v signal proportional to the 6v input...that way you should be reading double the voltage you have.
Well the way I see and how this works if the 6 volt changing system is not working to that voltage output then the reading on the SW gauge will go lower since it will read down to 10 volts. Thus showing whats going on with the charging system voltage rather simple to understand the reading on the SW voltage gauge.
How you determine a crayon and excitement can be related to the post is amusing for sure. Heck its possible not using the original amp gauge for a charge reading may also add economy to the equation.
