I'd be strongly tempted to remove the large-ish yellow wires from the battery side of the starter solenoid that power the rest of the car. So nothing else in or on the car gets 12v power.
Use a jumper wire to power the ignition coil & a remote start switch on the solenoid as needed. Don't leave the coil powered up if the engine isn't running, it can easily overheat.
