Bruce Lancaster
"I was in an old time generator shop and noted that they held the tool to remove the screws in a drill press. They turned it by hand but the press kept the tool in the hole."
There was also a sort of little jack that a generator shop put inside the case between the screw areas of the 2 field coils to support under the screws...removal sometimes required enough downforce to keep the driver in the little square to oval the case!
