f balsiger
can I use a stock 6v amps gauge in 12v neg ground system?
ok reverse wires. alternator goes to +?
You need to increase the resistance of the shunt so more goes through the ammeter. The ammeter gauge in my '32 reads almost exactly half so I just remember to double it. See photo. If I was doing it on my Model A where there is less room I would just run a second wire of the same gauge from the output of the generator or alternator to the opposite post on the ammeter.Using a shunt across the ammeter pretty much makes the amp gauge non responsive.
