Battery cable post clamp size is the best clue. Coil polarity is another. Ammeter wire color: if the wires on each firewall post match, it's positive ground; if reversed, negative.
Everything will work either polarity. As has been said, probably negative ground.
I just bought a 1930 Town car. The car has been converted to 12 volt. How do I know if it is negative or positive ground? Will it work either way or blow the fuse? The battery was not in the car.
My guess is that it is a 90% chance that it is negative ground. All modern electronics expects 12 volt negative ground so people usually make it that way.Battery was not in the car! 50 - 50 chance I would try neg ground it will not blow the fuse one way or the other, only if you have a short
I've seen this expressed before, and assume it is true but do not understand why the starter does not run backwards and be a problem, since it is a DC motor.
Can you/someone please explain?
Thanks
The key reason for the starter to always turn in the same direction is that the field winding is in series with the stator. When the direction of current changes both the field and the stator changes so the direction is the same.
If the field winding was in parallel with the stator, then reversal would occur with a change in the polarity.
Marc
Can you even get a positive grounded alternator? I believe all the alternators I've ever worked on had the ground to the case (none floated), and who would buy special diodes to reverse polarity? I'd bet a 4 pack of Heady Topper that if it's an alternator then it's negative ground.
