this is from Kens garage;
Battery
Any good 12 Volt battery will do as long as it will fit your battery box and hold down. I selected a 72 month, 675 cranking amp, universal battery.
Alternator
I installed a GM 63 Amp Alternator with an internal self exciting voltage regulator. The hook up is one wire, the same as the existing generator. You will need to make two small brackets to mount the alternator or you can use two shackle bars and drill out for the proper size bolts. An alternator pulley can be purchased from your friendly Model A parts supplier.
Starter
No modifications are necessary to the starter. Just touch the pedal and enjoy really fast starts.
Ammeter
I changed the standard 20 amp ammeter to a 30 amp ammeter as an alternator will peg the standard meter. You must reverse the leads on the ammeter due to the change in polarity of the battery. Your neighborhood Model A parts supplier carries the 30 amp ammeter.
Headlights
Since I installed an alternator I opted to go all the way for headlights and convert to Halogen bulbs. The conversion is relatively easy. You can purchase a kit to modify your existing reflectors or you can purchase new reflectors with the Halogen sockets installed. You must install an alternator to successfully operate Halogen bulbs.
6 Volt kits are available. What a pleasure to be able to really see while driving at night.
Ignition
You could install a 12 volt coil and a resistor to reduce the voltage to the points.
I elected to install a PerTronix IGNITOR electronic ignition system. This is an extremely easy system to install as it fits entirely inside the distributor; no outside boxes are required. Kits are available for the standard Model A or B, early V8, and Mallory distributors. Both 6 and 12 kits are available.
Kits are furnished with a new coil as the correct coil resistance is very important for proper operation. Kits are distributed by: Remund Ignitions, Inc.
P.O. Box 857
Lemon Grove, CA 91946-0857
(619)460-3620
Horn
Getting the horn to work properly was the most perplexing part of the conversion. I tried several "voltage reducers" from the local parts stores but none could handle the current demands of the Model A horn. I finally purchased a 0 to 2 Ohm variable power resistor with a 100 watt rating from an electronics supply house. I selected a variable resistor in order to optimize the voltage to the horn.
The resistor I purchased was am Ohmite D100K2RO ($15.87) with two Type 12 brackets ($0.55 ea.) (Newark stock nos. 13F671 & (2) 13F099) from:
Newark Electronics
1-800-463-9275
Branch offices of Newark are located throughout the United States. Minimum order is $25.00. An alternate approach would be to puchase a 12 volt horn.
Light Bulbs
The following bulbs can be used with a 12 volt system: Cowl, Tail, and Dash Lights - #89, 6 cp
Dome Light - #67/97, 4 cp
Stop Lights - #1156/10, 32 cp
Turn Signals
If you have a Signal-Stat turn signal it will be necessary to change the flasher to a Signal-Stat #180 and the bulb to a #1445.
