Need more details. What kind of generator was converted? How was the conversion done? Was it origunally a 3 brush? What year? Some clear, close up photos would help. The grounded wire coming out is likely the field. It should be grounded for use with a cutout.
If it only has 2 brushes, you must use a regulator. If a cutout is used the generator will run at max output continuously.
