Patrick L and Sparky are correct . I run my original generator on 12 volts with good results . Though the original type cutout can work , I use the Fun Projects can style voltage regulator that looks the same and takes the place of the cut out . No wires will need to be changed if you continue to run positive ground . If a person wants to change to negative ground , they will need to reverse the wires at the coil and the ammeter . The battery cables will also need to be switched to negative ground if you choose to run negative ground . An original or replacement six volt coil can be used on 12 volts If a resister is used at the coil connections . I prefer the cleaner look of a 3 OHM coil without the need of a resistor. I have used the Pertronix flamethrower coil for hotter spark , quicker starts and more power for better performance . The original starter has worked good for me as well as others . The bulbs will need to be changed and a resister will need to be used on the horn and electric windshield wiper if
used .
There are at least two voltage regulators that can be bused with the original generator on 12 volts. The Fun Projects can style voltage regulator has worked great for me . The Peterson 12 volt voltage regulator that connects at the generator band also works on the model A generator . The voltage regulator that takes the place of the adjustable third brush only can be used on six volts . If a person wants to use the most powerfull halogen head lamps and other high draw accessories they will need to use a 60 amp alternator . Being as all of the 12 volt alternators that are offered in the model A catalogs are negative ground , it will be necessary to change to negative ground if the 12 volt negative ground alternator is used ..
