Well I went and done it. I converted my 1930 Model A Ford Closed Cab Pickup to a 12 volt system with an alternator. Main reason was to provide halogen headlights and a good turn signal system.
However, I do not a functional Ahooga horn. In the conversion process, I did install a voltage reducer on the horn. The horn is not the problem, as it worked as it should before the conversion. In reading the forum threads, I see a horn resistor is mentioned.
So I have some questions. Does the alternator need to be "charging" for the horn to properly function? Is it safe to use a 6 volt horn, with a 12 volt system, or is it better to have a voltage reducer? Would a resistor to the horn be in order?
Thanks.
Thanks.
