jeepguy1948
I have made the decision to install a 12 volt alternator. Which set up is best and who to buy it from? Thanks
Nu Rex has both the 6 and 12 volt alternators. I had no problems with the 6 volt one I put on my car. Thay have the correct pulley and brackets... Chap
https://www.nurex.com/
Check out speedway motors #82006
I use 10SI 3 wire alternators and the Snyders mounting kits. Three wire setup uses an exciter wire that is remote from the alternator and detects low voltage. I always had trouble with the one wire alternators seeming to never start charging without revving up the motor. 10SI’s come in a hundred variations, but the mount and body can be ‘clocked’ every 90 degrees so the wiring connections are placed where you want. Just get one with the ampere rating you need. I’m no electrician, but these are simple enough for me.
