Forty-wuns foever
I have not been on here in a number of months and I have looked for my specific question but do not see it.
So here goes, I am installing a 12 volt alt on my 41 Ford flathead. The alt shares a bracket with an a/c compressor.
It will be running an electric cooling fan and the inside a/c fan, I am thinking a 90 amp will do for the alt.
The original voltage regulator is missing but there is a short yellow wire which looks like it would be the main feed back to the battery. Can this be used to connect the alt output (battery) wire instead of going to the solenoid.
I have a wiring diagram that shows this yellow wire going from the regulator through the gauge to the circuit breakers and to the battery side of the solenoid, the print is not very clear but that is what it looks like.
Any help is appreciated.
