Swap the wires to negative on the coil , ammeter and the battery . This will work if you install a twelve volt battery connected with negative ground . I run some of my model A's on twelve volt positive ground with all new original style wiring harnesses from Brattons and no changes to the wiring is needed .
What changes need to be done to the starter if converting to negative ground ? Seems like the starter will rotate in the wrong direction if not modified. Would the field contacts just need to be reversed ?
Thanks jr . I did use the modern starter drive and forgot to mention it . The modern starter drive wouldn't be a bad idea even with six volts ..
