A alan Well-known member Aug 29, 2013 #1 need to know if the 11" pressure plate and clutch will come out thru the trans hole of a 1941 engine in my 1 1/2 ton truck or do I have to remove the oil pan. this the sequel to the stuck clutch and I am taking it apart to replace the clutch
B Bluebell Well-known member Aug 29, 2013 #3 Does you pan have the removeable piece at the bottom. If it does, then by removing it, the clutch will come out. If not, pan off. Sorry.
A alan Well-known member Aug 29, 2013 #4 38 coupe/bluebell--I thought I would since I do not have the two piece oil pan
