Modern oil has polymers in there that hold the film build when hot. When I was a kid, I couldn't figure how they got thicker oil when hot and thin oil when cold since that is impossible for straight grade oils. After watching a guy dump a big bale of polymer material into a batch of multi-viscosity motor oil being blended up, it finally started to make sense. That polymer material really expands when it gets hot. On a fresh motor, I'd stick to SAE 10W30. After it gets worn out you can go to the 20W50 stuff. We used SAE 20W/20 for winter when I was a kid. We switched SAE 30 in the summer time. We changed the oil for each season change whether it had a lot of miles or not.
