- City
- GR
- State
- Michigan
I make this 10 LED Aluminum Brake Light that upon power flashes for a few seconds, and then goes to a steady on. It has been designed for vintage vehicles, as it operates on 6 or 12 volt systems, positive or negative grounds. It uses a plug and jack so it can easily be installed and removed, in case you would like to remove for a show event.
http://www.brakeflasher.com/brake_al.htm
