41panelmark
Hello guys.
I need a bit of help on the following.
1940 Ford
Car is 12 volt, negative ground.
I would like to install 12 volt, self-regulated 1 wire alternator with correct shaft for large flathead belt pulley.
1 What is the part number for an appropriate 65 amp internally regulated (1) wire alternator to fit the sling-shot style bracket for the flathead?
2 What is the proper wiring set up for this application? (not using stock regulator).
3 Would like to work with someone who has done this with good results.
4 Results should be an alternator that charges around 13.8 with a new battery +/-.
1940 Ford
