AnthonyG
DD, I’m an old fart w very thick skin & been around a long time mostly in groups where if u can’t take the heat get outa the kitchenAnthony.....I want you to understand that I have NOT been trying to bust your chops in this thread. I just don't want to see you damaging your stuff, or end-up injured in any way. I've just spent better than an hour trying to verify that ARP part number, although that 150-2201 is the one that I tentatively jumped on initially. The problem is that ARP doesn't seem to list specific application info as far back as our flatheads. Those 150-2201 bolts "look" about the right size, BUT...…….! Those -2201 ARP bolts' actual dimensions are 5/16"-18 thread, with an overall length of shank UNDER the head (shoulder AND threads) of 0.780". So, how long are the shanks on your current bolts...UNDER the head?
I see where it looks like Kube may be attempting to find you a GOOD flywheel. Isn't your engine an 8BA-type ('49-'53) engine? If so, the replacement flywheel MUST be a matching 8BA-type. DON'T let anyone tell you differently!! 8BA f'wheels can be identified by the six bolt holes being drilled all the way through the flywheel. Earlier f'wheels have "blind" holes….NOT drilled all the way through to the opposite side. You need to stipulate WHICH type of flywheel you need.
If I had a spare wheel layin'-around, I'd send it your way for the freight. Unfortunately, I DON'T have one layin'-around, but I'll bet half a dozen guys reading this thread have a decent one layin' in a corner, never to be used again, that could sell or donate to your cause for the freight cost. So, what type of flywheel you got, and what is bolt shank length of your six original bolts? And just to be sure, will a common 5/16" "coarse"-threaded bolt thread into one of the undamaged, threaded holes? DD
Now, the info Yes engine is an 8BA, shank length r 1”, threads r 5/16”-18
No harm no foul!
