I worked for a few years with a company that did truck commercial truck up-fitting and frame modification for all sorts of commercial duty applications for light duty, medium duty and heavy duty, body installations, cranes, etc. so I saw firsthand the extra engineering that sometimes had to be done to make certain trucks fit for the service they were needed for.
It's not just the addition of helper springs that would automatically render the Model A pickup worthy of carrying an appreciable amount of excess weight. They can only do so much if you are planning to burden the Model A frame/suspension system with more weight than it was designed to carry. Don't forget to give strong consideration to the other suspension components in play that are directly affected by stresses and loads beyond designed limits such as the frame, axle shafts, axle tubes, axle bearings, wheels & tires, brakes, etc. With the Model A pickup bed overhang bias being more to the rear of the center of the rear axle, improper load distribution can have a dangerous effect on braking and handling and going around turns when loaded. The Model A pickup might be able to handle the extra loading you speak of while sitting still, but going down the road is a completely different matter. I urge you to be very careful here.
