Will Kimble
I put my Dad's nice old Zenith on my jalopy, and gas poured out of the bowl while it was running. I figured the float wasn't closing for some reason, so I popped it open and sure enough - there was a grose-jet style float valve in there and the ball was stuck. I zapped it with brake cleaner and dug out a loose shard of brass, and it still wouldn't move correctly so I pitched it in the trash.
I installed a new original-style float valve and it lifted the float quite a bit - made it close earlier. My Les Andrews book recommends modifying the gasket to get the float level, so I sanded the gasket as thin as I could stand and put it back together. It is almost level but not quite.
Can I install the float valve with no gasket? Or should I cut a new gasket out of thin gasket material?
Thanks,
Will Kimble
Thanks,
Will Kimble
