Hi to all! I'm new to the forum and also new to the world of the Y block motor. I have tried searching for the answer to the question I have but keep coming up with a blank so any help would be appreciated.
I recently purchased a 1961 Galaxie with 292 motor to run around with this summer while my 1978 F100 undergoes a frame off rebuild. The plans for the galaxie is to clean it up and get it running better. Like I said it has a used and abused (but running) 292 2 barrel motor. The rear breather that should be on the Valley pan with a screw is gone as well as the road draft tube. My question is; Where can I find a replacement breather?? I have read about guys blocking off the breather hole and installing a PCV valve into the valley pan. Is there already adapter to do this or do I have to fabricate a set up for this? I'm trying to go low budget on the Galaxie so I can save money for the F100. Thanks
