WTB rear frame section only
steve hackel
midlothian
illinois
I am looking to buy the 2 rear frame sections only - I do not need the rear cross member, nor do I need the center cross member. If someone has a pair of rails, just remove the rivets from the rear spring cross member and also the center cross member, and cut the 2 rails in the middle , or just forward of the center cross member. I plan on replacing the rivets and then splicing the rails in the middle of the center cross member . In the end, I will eventually have a great looking, square and parallel frame for my coupe.
I have looked at other poor frames, I have tried to find a good frame with no results - mostly due to locations and shipping issues. If someone has a rear frame section they are willing to part with, I am interested !;)
Just a follow up - if no one has a pair, I can easily get by with the passengers side rear rail and then eventually straighten the drivers side. The passenger side is paramount to repairing my frame. Thanks
