window help please.
1936coupe
just wound up windows to wash car, one has jammed up and will not wind down any ideas? imagine got to remove door card and have a look?thanks.
yes removing the door card to view the malfunction is the solution. post some pictures of the problem thanks!
Dunno if this will work, but you know how on a 36 the window winds up, then forward?- well possibly try opening the door so you can grasp both sides of the window, and see if you can possibly move it forward or back slightly to engage the peg in the slot that provides the forward/aft movement. There may be a slight misalignment problem? Brian
