Window Anti-rattler Help
Sorry about that. Drivers door of 56 Fairlane. Working on the outer anti rattler. It has the snap in clips. Toward the front of the car, the window will push in enough to get it in but on rear part of door, the window is tighter. I was hoping to replace without messing with window mechanism. Took it out to clean and honestly it is in pretty bad shape so I was thinking about replacing all of them...kind of expensive though. Either way, I have to put back in.
easier to do with the glass dropped i think you can undo the pins on the ends that hold the glass to the regulator without touching any adjustments this should let the glass drop into the door far enough to install the wiskers just hold the glass so it does not drop maybe stuff a towel in the bottom of door
