Wind wing part 2
56sedandelivery
So I am disassembling my 56 wind wings for rebuilding. Got the seal off fairly easy and now working on the channel that the main window rides in. There are three places that are riveted to the wind wing frame. The bottom one was no problem but the other two areas have me stumped.
In the first pic I can probably get the rivets out if I can find a long drill bit. I just cannot get a standard size bit to get in there.
The second pic is the one giving me fits. The rivet are on the inside of the frame and I cannot see any way to drill them out. Any ideas on this?
Also where can I find the correct rivets to reinstall all this?
I use extended bits when I have side clearance problems. The long ones are 10 to 12 inches long. When they are that long, a person can bend them a bit off center if you hold the shank of the bit when it's turning. I would recommend gloves but I generally don't use them. They are sized in wire gauge. #40 is 3/32", #30 is 1/8", and #21 is 3/32" so you need to know the diameter of the rivet shank to get the correct size. Aircraft tool suppliers have these extended bits and you can get them in fractional sizes as well. You may need a correct size pin punch too. A small narrow chisel would be good to have if it starts to go off center a bit.
I have a 1/4" X 28 tpi size 90 degree drill that uses that size thread attached to different length and size bits and all the normal size bits for that. Even that small bit set up may not fit in there. Aircraft and helicopters are put together with rivets so I have all that stuff to do those tight fit jobs and wouldn't you know, I end up using them a lot.
ATS, Aircraft Spruce, or one of the other aircraft tool suppliers will have this stuff as well as specialty machine tool suppliers.
Got the pieces apart with the longer drill bit. It appears that the holes are 9/64 in diameter. It looks like the original rivets were the tubular type. The parts to be rejoined are from .175 to .190 in thickness. Would a 9/64' x 1/4' rivet be too short for this?
I would purchase rivets for the thickness I needed to join and the next longer size just in case. You can shorten a tubular rivet but you can't add too it. The tubular rivets have to set proud enough through the joined thickness to be able to curl around for a normal set. Sometimes you have to experiment when doing these things and it can cost a few rivets to get good results so get enough quantity to cover all the possibilities.
Are you kicking yourself for no reason with these rivet sizes?
You are going to buy the vent window rubber seal kit from Dennis Carpenter anyway, right? And you will need to get the custom-fit window channel kit for the rail right?
When I redid all my vent windows (latest was in 1999), back then they furnished all the new rivets of correct size in the kits.
I have all the gaskets and seal for doing this. The small strip seal came with rivets. The C shaped rubber gasket does not have rivets. The window channel that the side window goes up and down in did not come with any rivets. That was the piece I needed to find the correct rivets for. I ordered some 9/64th x 3/8 and will see how they work. May have to order some a bit shorter but at least getting there.
I had my glass guy do my vent glass and door glass, he did all the hard work. I supplied the glass and whatever seals that were needed.
On the '59 Ford, there is a rigid piece of channel that screws to the vent window frame. I had to cut the channel to size, mill and drill all the slots and holes from my OG piece that was in bad shape.
I wouldn't be a bit surprised if a glass shop just glued the window fuzzy channels to the door frame and the front and rear door glass run channels rather than duplicating what the factory did with rivets and clips.
When I did mine, I couldn't bring myself to trust a glass shop to do it right. I kept the original clips that go along the top and back of the fuzzy window channels and replaced all my rivets exactly as the factory had done.
Straightening the top and back side clips with needle-nozed pliers prior to re-installation is tedious, and setting up for punching the rivets can be a pain too, but at least it will hold as good as new.
All he did was to set the glass in the vent frame and window lift channel. I knew there was different thicknesses of the setting tape. The rest I did.
