Which Timing Gear?
31 Woody
Probably not a good question as I am only looking at a $90 decision…but, here goes:
I have a rebuilt B engine to install in my Cabriolet. The B block currently has a new fiber gear installed. I am considering pulling that and installing an aluminum one. Backstory though—Several years ago the engine on our Station Wagon decided it wanted ‘love’. As it was getting the attention it needed, a good friend was doing the work and said he was installing an aluminum gear. I initially protested, and he asked “do you like changing timing gears on the side of the road?” Wow, what a great response. Nearly ten years later the wagon is fine, but we have probably only put 3 or 4 thousand miles on it. So now I have another Model A, that won’t get a million miles on it…. The fiber gear will probably last forever based on my usage. But it’s apart already. How many miles/years should someone expect from the fiber gear?
I do realize the crank gear and backlash are something that needs to be considered as well. I do not know if the crank timing gear is new or used, but I do plan to check. Thanks!
In the 1960's I changed a timing gear on the side of the road. So I have an aluminum gear in my car now.
This is like the question of what oil to use.
I have replaced a number of timing gears in my 60 plus years of driving Model A’s.
I have always used a new fiber gear.
Enjoy.
When my old fiber gear failed, I pulled the engine so that I could clean the pan, easily adjust valves, etc.
There is a bronze gear available, also. http://www.modelaparts.net/special.htm/bronzegears.html
That link is to Dennis Piranio's website. Dennis passed away and I am pretty sure Beth closed the business. That gear is actually made by Dan McEachern, ...who from time to time does frequent Fordbarn. PM me if you need Dan's e-mail, -or check with Steve at Berts to see if he has one in stock.
I have aluminum timing gears with new crank gears in both of my A's. I have piece of mind and they don't make noise. What's not to like. :)
"How many miles/years should someone expect from the fiber gear?" Anyone want to stick their head above the parapet and answer the OP question ???:) (for my two pennyworth I'd guess 20-30K miles if using modern oils)
Maybe that is why you have replaced a number of timing gears in your 60 plus years of driving Model A’s. :rolleyes: :rolleyes:
All replacements were in different cars. Only one car I’ve owned actually had a timing gear fail. New gear was normally one of the first things I would do.
Our last car, that we just sold after 42 years, still had the fiber gear in it that I installed in the early 80’s. Checked it before we sold car. Gear had minimal tooth wear.
I agree that with the typical mileage put on these cars yearly. They should last many owners. On a high mileage driver, I would think about the aluminum gear, think about it.
Enjoy.
The gear tooth contact has to be right, virtually no play. If there is much play the harmonics of the 4 cylinder crankshaft will chatter those fiber gear teeth right off.
Not to mention the motor modifications over the years
Adding more valve spring and or cam profile will beat up the stock gears
In fact the way the engine is driven will also contribute to the deterioration of the stock gearset
