Hold a lug nut in the hole and look at the rear side.It should not protrude.If it does,it will bottom out on the swedge of the stud without really tightening the wheel.Check with a good original lug,old repros may stick through anyway.I found a nice old set of repros,but I had to grind a little off the ends to get them to seat in the taper.
